Forum > Bazar - ostatní > P: FHD multitouch display 23"
 o Navštíveno 4698x o
o 02.02.2014, 20:58 | empi
zdravím, nabízím zde svůj dotykový panel značky Hewlett Packard typ: 2310ti..
Jedná se o multidotykový panel. Vše 100% funkční bez závady.
LCD panel
23-inch Wide-Aspect Active Matrix Thin Film Transistor (TFT)
Viewable image area
58.42 cm (23.0 in) widescreen; diagonally measured
Screen opening (H x W)
28.84 x 51.13 cm (11.4 x 20.1 in) - bezel opening
28.64 x 50.92 cm (11.28 x 20.05 in) - panel active area
Panel type
TN with CCFL back-lit LCD with BrightView
Aspect ratio
16:9
Viewing angle (typical)
Up to 160° horizontal/160° vertical
Brightness (typical)
275 nits (cd/m2 ), includes loss for touch screen glass
Contrast ratio (typical)
1,000:1
Dynamic contrast ratio (typical)
40,000:1
Response time (typical)
5 ms (on/off), 3 ms (gray to gray)
Pixel pitch
0.2655 mm
Pixels per inch
95.7
Backlight lamp life (to half brightness)
50,000 hours
Color gamut
72% typical
Horizontal frequency
24 to 94 KHz
Vertical frequency
50 to 76 Hz
Native resolution
1920 x 1080 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
1920 x 1080 @ 60 Hz
1680 x 1050 @ 60 Hz
1600 x 1200 @60 Hz
1440 x 900 @ 60 Hz
1280 x 1024 @ 60 Hz
1280 x 960 @ 60 Hz
1280 x 720 @ 60 Hz
1024 x 768 @ 60 Hz
800 x 600 @ 60 Hz
720 x 400 @ 70 Hz
640 x 480 @ 60 Hz
Text mode
720 x 400 @ 70 Hz
Maximum pixel clock speed
200 MHz (VGA); 170 MHz (DVI)
User programmable modes
Yes (20)
Anti-glare
No
Anti-static
No
Default color temperature
6500 K
Plug and play
Yes
Input connectors
(1) VGA, (1) DVI-D with HDCP
Input impedance
75 Ohms (VGA); 100 Ohms differential (DVI)
Sync input
TTL separate synch
Video cable
One DVI-D to DVI-D
Video cable length
1.8 m (5.9 ft)
Audio
Integrated speakers (2 W per chanel) with 3.5 mm stereo mini-plug input
Audio cable
3.5 mm stereo mini-plug cable
Audio cable length
1.8 m (5.9 ft)
Input power
90 - 265 V ac, 45 - 63 Hz
Typical power consumption
47 W
Maximum power consumption
56 W
Power saving
< 2 W
Power cable length
1.9 m (6.2 ft)
Cena 4000,- (PC_ 11 000,-)
ilustracni obrazek: [ Link ]
Stránka vygenerována za 0.3286 sekund.
