Forum > Bazar - ostatní > P: Monitor EIZO nový
 o Navštíveno 4088x o
o 17.05.2015, 06:52 | Reprák
Prodám tento nový monitor Eizo S1503 - 15".
+ příplatkový stojan z high end modelu. možnost rotace a výškového nastavení. Foto reálné!
Koupil jsem si jej jako třetí ke stanici cca před rokem, ale zapojil jsem poprvé až nyní, tzn je nový. Kupoval jsem ho z Anglie, takže není záruka.
Monitor je ale uplně nový bez jedinného poškození. Stál mě na naše okolo 12000kč, nyní prodávám za 1/4 ceny.
Výborný profimonitor, repráčky, ecomode samostvívání podle jasu okolí a jiné vychytávky. Možnost osobního převzetí. K monitoru nový audio a VGA kabel.
LED Backlight
With an energy-saving LED backlight, the FlexScan S1503 uses only 6 watts during typical operation. The LED backlight does not contain any mercury for minimal environmental impact when the monitor is eventually disposed of.
Digital and Analog Inputs
connectorsWith both DVI-D and D-Sub mini 15-pin inputs, you can use a computer that has either a digital or an analog graphics board (or both if connected to two computers), and quickly switch between the inputs via a front panel button.
Optimized Brightness with Auto EcoView
auto ecoview sensorThe Auto EcoView function is a sensor on the front of the monitor that measures ambient light and optimizes the screen's brightness Since the screen is never too bright, eye strain is reduced while power consumption is cut by up to 50% compared to operating the monitor with Auto EcoView turned off and set to the default factory brightness of 100%.
Built to Last Five Years
EIZO’s five-year warranty is two years or 67% longer than the standard three-year warranty of most brands. Even if the initial purchase price of the FlexScan S1503 is higher than another 15-inch monitor, the TCO (total cost of ownership) will likely be lower due to the significantly longer buying cycle and less need for repair.
5_vs_3.jpg¨
Cabinet Color Gray, Black
Panel
Type TN
Backlight LED
Size 15" / 38 cm (380 mm diagonal)
Native Resolution 1024 x 768 (4:3 aspect ratio)
Viewable Image Size (H x V) 304.1 x 228.0 mm
Pixel Pitch 0.297 x 0.297 mm
cena 2600kč.
foto k příspěvku  od Reprák
Stránka vygenerována za 0.3221 sekund.
