Forum > Bazar - autohifi > P: Magnat Thunderbull 3000 XL
 o Navštíveno 1407x o
o 20.06.2011, 13:08 | Felishita
Prodám "tubu" Magnat Thunderbull 3000 XL cena je na dohodě.
o 21.06.2011, 15:01 | Felishita
1500,- !!
o 21.06.2011, 20:06 | Felishita
Za 2000 i se Zesíkem Magnat Rock 4000
TECHNICAL DATA ROCK 4000
Stereo / Bridged
Max. output power (1 kHz sinus burst 2:8, B+=14.4V) 2 x 160 W / 1 x 500 W on 4 Ohm
Nominal output power (DIN 45 324, B+=14.4V) 2 x 65 W / 1 x 200 W on 4 Ohm
Max. output power (1 kHz sinus burst 2:8, B+=14.4V) 2 x 250 W on 2 Ohm
Nominal output power (DIN 45 324, B+=14.4V) 2 x 100 W on 2 Ohm
Loudspeaker impedance (stereo) 2 – 8 Ohm
Frequency response 5 – 50 000 Hz (-3 dB)
Total harmonic content (DIN 45 403) < 0.05% (1 kHz)
Stereo separation (IEC 581 ) > 60 dB (1 kHz)
Weighted noise distance (IEC A) > 100 dB
Input sensitivity LOW LEVEL INPUT 250 mV – 4 V
Input impedance LOW LEVEL INPUT 20 kOhm
Low-pass filter 40 – 300 Hz, 12 dB per octave
High-pass filter 40 – 300 Hz, 12 dB per octave
Bass boost 0…12 dB at 45 Hz
Supply +12 V (9 – 15 V), minus to ground
Fuse 1 x 30 A
Sizes (W x H x D) 221 x 48 x 253 mm
Weight 2.35 kg
Stránka vygenerována za 0.3573 sekund.
