Forum > Bazar - autohifi > P: SW Peerless XXLS 10
 o Navštíveno 12514x o
o 07.08.2014, 15:24 | japonec1 | Upraveno: 2014-08-07 15:29:14
Predam prcka SW peerless XXLS10cw v uzavretej bedni cca 17L. SW je funkcny nic mu nieje ja ho uz nevyuzijem. Ohladom vykonu na de forach to riesia kolko mu pustit daval som okolo 250 rms na 4ohm. Zvukovo velmi pekny tvrdy presny bass a ked treba tak aj zatlaci. Cena 130 eur. Foto pridam
o 07.08.2014, 20:02 | japonec1
nejake info:
Electrical Data
Nominal impedance Zn 4 ohm
Minimum impedance Zmin 2.2 ohm
Maximum impedance Zo 26.5 ohm
DC resistance Re 1.7 ohm
Voice coil inductance Le 1.5 mH
Capacitor in series with x ohm Cc -- uF
T-S Parameters
Resonance Frequency fs 39 Hz
Mechanical Q factor Qms 6.79
Electrical Q factor Qes 0.47
Total Q factor Qts 0.44
Force factor Bl 10.4 Tm
Mechanical resistance Rms 4.37 Kg/s
Moving mass Mms 121.1 g
Suspension compliance Cms 0.14 mm/N
Effective cone diameter D 21.2 cm
Effective piston area Sd 352 cm2
Equivalent volume Vas 23.6 ltrs
Sensitivity (2.83V/1m) 92.2 dB
Ratio BL/√(Re) 7.9
Ratio fs/Qts F 88
Power handling
100h RMS noise test (IEC) -- W
Long-term Max Power (IEC 18.3) -- W
Max linear SPL (rms) @ power -- dB/W
Short Term Max power (IEC 18.2) -- W
Voice Coil and Magnet Parameters
Voice coil diameter 51 mm
Voice coil height 33 mm
Voice coil layers 4
Height of the gap 8 mm
Linear excursion +/- 12.5 mm
Max mech. excursion +/- -- mm
Flux density of gap -- mWb
Total useful flux 2.4 mWb
Diameter of magnet 147 mm
Height of magnet 35 mm
Weight of magnet 2.4 Kg
o 13.08.2014, 00:19 | japonec1
foto k příspěvku  od japonec1
o 13.08.2014, 00:20 | japonec1 | Upraveno: 2014-08-13 00:21:54
o 14.08.2014, 16:43 | Diner
jeee, muj byvalej. Velice sikovnej prcek, doporucuju.
o 15.08.2014, 00:08 | japonec1
Diner: velmi dobry basacik , ale prisla rodina a tak pomaly vsetko ide do sveta:-)
o 27.08.2014, 11:09 | japonec1
Predaj Zruseny. Ostava u mna.
o 04.06.2015, 08:11 | japonec1
Znova aktualne ceny sa troska upravili. Na predaj aj zosik dls ca23, kmplet krabica stav A1. Cena Sw+Zosik 250 eur.
o 04.06.2015, 13:58 | noclue
este ked mus spravis lepsiu ozvucnicu (BP 20/40) a das 250-400W zo zosika s dobrou kontrolou, tak to ten menic vie presne, rychlo a pre vacsinu aj dostatocne hlasno
o 04.06.2015, 22:05 | japonec1
Noclue: mal som ho na genesis ultra a zvukovo pohoda, tie presne a rychle basy tam boli aspon pre moje ucho. Ina ozvucnica by vela zmenila ... but no time.
Aktualne :-)
o 06.06.2015, 23:38 | 1kw
noclue prosím tě jaký objem a port by byl pro 12" repro v BP ? (Peerless, Genesis, Xetec)
Nemůžu nají žadné info. Nechci laborovat, Děkuji
o 07.06.2015, 00:22 | noclue
bez laborovani to nejde
35/70 a port 300cm2 ladit od 60-75Hz, podla toho,ako ho chces ako vysoko ma hrat potom LP55-65Hz -18 resp -24dB
realnu dlzku portu zistis az v aute...
o 14.06.2015, 13:49 | japonec1
Aktualne
o 09.07.2015, 22:20 | japonec1
aktualne
o 22.07.2015, 13:51 | japonec1
Cena dls ca23 + peerless = 240 eur
o 29.07.2015, 09:33 | japonec1
Cena 200 eur do 2.8.15
o 29.07.2015, 09:37 | Wendy
Kolik za samotný ca23?
o 29.07.2015, 21:38 | japonec1
Wendyna: neviem .... zatial predaj ako celok
o 30.07.2015, 08:19 | Wendy
Já si ho stejně spletl s ca22
o 06.08.2015, 23:22 | japonec1
Aktualne
o 09.08.2015, 20:19 | japonec1
Cena dls ca23 + peerless = 230 eur dohoda
o 26.08.2015, 21:21 | japonec1
Cena 210 eur
o 04.10.2015, 23:24 | japonec1
Cena 200 eur
o 03.11.2015, 16:12 | japonec1
Cena 190 eur
o 08.11.2015, 20:27 | japonec1
Cena komplet 190 eur.
o 10.11.2015, 19:45 | japonec1
up
o 10.11.2015, 19:46 | japonec1
up
o 11.11.2015, 08:40 | japonec1
Aktualne
o 19.11.2015, 21:25 | japonec1
Up
o 17.01.2016, 08:49 | japonec1
Komplet 180 eur dohoda mozna.
o 25.01.2016, 08:56 | japonec1
170 eur
o 05.02.2016, 11:57 | japonec1
Chris. Odpisane na email
o 17.02.2016, 08:27 | japonec1
Up
o 22.07.2016, 23:18 | japonec1
Zosilovac predany.
SW na predaj cena 80 eur. zbytocne zabera miesto v skrini.
o 16.08.2016, 08:37 | japonec1
Up
o 05.10.2016, 12:49 | dioda
Je ten SW ešte aktualny?
o 09.10.2016, 08:36 | japonec1
Ano je aktualny
o 09.10.2016, 22:15 | dioda
A aká je aktuálna cena?
o 10.10.2016, 10:28 | japonec1
80 eur pane
o 28.10.2016, 23:36 | japonec1
Akcia do 4.11. ------ 60 eur
o 29.10.2016, 02:42 | japonec1
o 29.10.2016, 08:11 | Jujk0
Mám záujem, písal som mail. Ako by sme vyriešili dopravu k NZ?
o 29.10.2016, 19:32 | dioda
Pošli mi kontakt a idem si po.
o 31.10.2016, 19:06 | japonec1
Jujk0 email odpisany.
Dioda v profile mam vsetko potrebne
o 01.11.2016, 16:57 | japonec1
Aktualne ...... len osobny odber
o 07.11.2016, 18:35 | dioda
prcek je na mieste a zacina ladenie
foto k příspěvku  od dioda
Stránka vygenerována za 0.3356 sekund.
