Forum > Bazar - autohifi > P: Monoblok JL E1800D
 o Navštíveno 9105x o
o 25.07.2017, 13:17 | hotdog
prodám tento monoblok kupovaný od Pavla528, cca rok v autě na eascu, nyní 2 roky doma. není problém odzkoušet v autě.
cena 6000,-
e1800D Specifications
GENERAL SPECIFICATIONS:
Recommended Fuse Value: 80A
Recommended Fuse Type: AGU or MaxiFuse™
INPUT SECTIONS:
No. of Inputs: One Stereo Pair
Input Type: Differential, noise-cancelling with RCA jack
inputs (low-level) and multi-pin jack (high-level)
Input Range: 200mV - 8V RMS
AMPLIFIER SECTION:
Amplifier Topology: H-Bridge, Class D Mono
with impedance optimization and patented
discrete drive circuitry
Power Supply: Unregulated MOSFET switching type
Rated Power @ 12.5V (Mono):
480W RMS x 1 @ 4?
800W RMS x 1 @ 2?
THD at Rated Power: <0.08%
(20 Hz - 250 Hz)
Rated Power @ 14.4V (Mono):
640W RMS x 1 @ 4?
1000W RMS x 1 @ 2?
THD at Rated Power: <1%
(20 Hz - 250 Hz)
Signal to Noise Ratio: >95 dB referred to rated power
(A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response: 10 - 250 Hz (+0, -1 dB)
Damping Factor: >500 @ 4?/50 Hz, >250 @ 2?/50 Hz
AMPLIFIER FILTER:
Amplifier Low-Pass Filter: State-variable, 12 dB/octave
Butterworth or 24 dB/octave Linkwitz-Riley with
continuously variable cutoff frequency selection
from 40 - 200 Hz. Defeatable.
PREAMP OUTPUT:
Pass-through type. Output signal is identical to the signal at
the Amp Inputs.
DIMENSIONS (LxWxH):
15.75" x 9.25" x 2.36" (400mm x 235mm x 60mm)
o 01.09.2017, 08:33 | hotdog
up
Stránka vygenerována za 0.538 sekund.
