Navštíveno 7354x
ahoj,
prodám tyto dva zesíky, asi ne nutno představovat, jsou ve velice pěkném stavu i s origo krabicema. Málo používané a plně funkční.
cena jednotlivě Kč 2 900,- / KS, cena dohromady Kč 5 000,-
Specs:
LRx 1.400:
•900 watt Monoblock Amplifier
•Designed to drive very low loads
•RMS Power Ratings:
?350 watts x 1 @ 4 Ohms
?650 watts x 1 @ 2 Ohms
?900 watts x 1 @ 1 Ohm
•Limit Led: Overload Protection Circuit Indicator
•On/Off Led
•Safety Led
•Subsonic Bypass
•Output level adjustment
•Phase inverter (0°-180°)
•F1Q: Lo-Pass filter Q factor adjustment
•Built-in Crossovers: HPF(40 - 500Hz), LPF(40 - 500Hz)
•Subsonic Filter: Pre-set @ 20 Hz, Adjustable from 16 - 32Hz by replacing special resistors
•1 Pair RCA Outputs: Hi-Pass or Bypass
•Optional Bass Remote Modules Available Seperatley
•Dimensions: 370mm L x 176mm W x 56mm H
•1-year SonicElectronix.com warranty
LRx 4.300:
•High Power 4-Channel Amplifier
•RMS Power Output:
?4 Ohms: 65 watts x 4 chan.
?2 Ohms: 105 watts x 4 chan.
?4 Ohms Bridged: 210 watts x 2 chan.
•PWM MOSFET power supply
•2-Way Butterworth Crossover: High Pass @ 12 dB/oct. and Low Pass @ 12-24 dB/oct.
•RGP(Resettable Ground Protection) Circuit
•Darlington configuration
•Compact design
•Line Input and Output
•S/N Ratio: 105 dB
•THD: 0.009%
UP, nikdo nechce dva sympatický taloše? :-D
tak co chlapci, nikdo nic? Rozumná dohoda možná ;)
18.06.2018, 12:46 |
Sodom Ahoj. Měl bych zájem o ten monoblok. Kontakt pod nickem.
rezervace na oba kousky:)
Taliáni prodáni, díky za prostor :)
