Forum > Bazar - autohifi > P: 2x DLS TA2
 o Navštíveno 8982x o
o 28.11.2022, 22:22 | pospa
Mám na prodej dva zesilovače DLS TA2
Specification:
Number of channels: 2
Amplifier class: AB
Mono bridge mode 4 ohm: N/A
Output power in 2 ohm: 2 x 200 W RMS
Output power in 4 ohm: 2 x 100 W RMS
Damping factor: >240
S/N ratio, A-weighted: >102 dB
Frequency range: 10 Hz - 50 kHz
Input sensitivity: 0,5 - 7V
Input impedance: > 10 kohm
Input impedance, high level: N/A
High pass filter: 20 - 200 Hz, 12 dB slope
Low level output: No
High level input with auto start: No
Dual DC inputs: Yes
Power consumption (idle): 1,5 A
Power consumption (max): 40 A
Dimension (W x D x H): 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Rec. power cable: Minimum 5AWG / 16 mm2 for each channel / kanal
Fuses: 2 x 20 A
Dole na stránce odkazy na testy:
o 09.01.2023, 20:32 | pospa
UP
o 02.02.2023, 06:38 | pospa
Cena dohodou
Stránka vygenerována za 0.3365 sekund.
