Forum > Bazar - autohifi > Zesilovač TARAMPS SMART 5
 o Navštíveno 9814x o
o 27.06.2023, 19:07 | Luxík100
Nabízím pár měsíců použity zesilovač značky Taramps Smart 5.
Prametry
Class D
@ 12.6 VDC - 1 ohm: 5000 Watts RMS
@ 12.6 VDC - 2 ohms: 5000 Watts RMS
@ 12.6 VDC - 4 ohms: 2900 Watts RMS
INPUT SENSITIVITY 0.22V ~ 4V
SIGNAL TO NOISE RATIO >90dB
FREQUENCY RESPONSE 10Hz ~ 8KHz (-3dB)
CROSSOVER HIGH PASS (HPF) 10Hz ~ 90Hz (-12dB/8?) Variable
CROSSOVER LOW PASS (LPF) 90Hz ~ 8KHz (-12dB/8?) Variable
BASS BOOST Freq.: 35Hz ~ 55Hz
Boost: 0 ~ +10dB
EFFICIENCY 84% @ 1 ohm
86% @ 2 ohms
INPUT IMPEDANCE 10K ohms
OUTPUT IMPEDANCE 1 ~ 2 ohms
PROTECTION SYSTEM Output short circuit
low/high voltage protection
thermal protection.
MINIMUM SUPPLY VOLTAGE 9.5VDC
MAXIMUM SUPPLY VOLTAGE 16VDC
CONSUMPTION AT REST 3.60A
MAXIMUM MUSIC CONSUMPTION 236A @ 1 ohm
230A @ 2 ohms
MAXIMUM CONSUMPTION IN SINUSOIDAL SIGNAL 472A @ 1 ohm
460A @ 2 ohms
DIMENSIONS (228 x 70 x 428mm)
WEIGHT (5,10Kg)
Cena: 14 500.
foto k příspěvku  od Luxík100
o 07.07.2023, 15:14 | Luxík100
Při rychlém jednání sleva
o 16.07.2023, 17:01 | Luxík100
UP CENA 12 000KČ
Stránka vygenerována za 0.3712 sekund.
